Well, we've been burning since about September 15th, have burned through 2-1/2 cords of wood in the process. I like to give my chimney a cleaning around the first of the year and with the break between Christmas and New Year's Day, I went about this chore.
The Woodstock Keystone (cat stove) is on an interiior chimney, 6 inch rigid with 1/2 insulation. The Englander 30-NCH (non-cat stove) is on an exterior chimney, Metalbest, 6 inch with a chase around it.
Our weather in my neck of the woods has been colder than normal, hence firing the stoves in mid-September, however, December has been relatively mild. Typically, we burn the Keystone 24/7 or near it and fire off the Englander when the temps plunge. Though we burn the Keystone constantly, we have put about 1-1/2 cord through it and 1 cord through the Englander. The Keystone's firebox is about 1.5 cu ft and the Englander's is 3.5 cu ft. Whatever the real measurements are, we typically load double the amount of wood into the Englander and sometimes more. Both stoves are great burning stoves.
So - here's what I got today: The Keystone chimney gave-up 1-1/2 quarts of grainy, coffee ground, black creosote. The Englander gave-up 1 quart of very fine, almost dust/dirt like creosote.
Given my learning curve with the Englander, I expected more creosote, but was surprised at the lack of it.
For the Keystone, I clean it top down. For the Englander, I set the chimney such that I can do it bottom up - and it worked like a champ. I use flexible rods that screw together with a poly brush. I also have a Soot Eater gizmo and used it to clean the stove pipe. On the Keystone, it is vented horizontally into the liner. I used on section of the Soot Eater and put it throught the top vent opening (which is otherwise capped) and brushed via cordless drill back to the tee - worked great. For the Englander, I took down the stove pipe and used the Soot Eater to clean that too.
The SS cat I am burning this year on the Keystone is working great. It had a bit of fly ash plugging some openings, but was otherwise clean. I vacuumed the cat, took down the scoop, vacuumed it too.
BRING ON THE COLD WEATHER!!
How's your stove doing at halftime? How much creosote are you getting vs. wood consumed this year?
Thanks!
Bill
Thanks!
Bill
