when burning low and slow cat burns of most pollutants,when you bypass cat to get midwinter heat when it's -20 does that not negate the benefit of cleaner burns i.e turns into smoke dragon.just asking lol don't jump down my throat
curious
![lol ;lol ;lol](/talk/styles/default/xenforo/smileys/lol.gif)
Why would you bypass the cat for more heat? You just open up the airwhen burning low and slow cat burns of most pollutants,when you bypass cat to get midwinter heat when it's -20 does that not negate the benefit of cleaner burns i.e turns into smoke dragon.just asking lol don't jump down my throatcurious
Wood savings only comes in when your burning at lower burn rates simply because the available btus are stretched out over a longer period of timeso it's just wood savings that change.
I mean in some stoves there is a slight efficiency gain with a cat over a comparable size and quality non cat. But really not enough to show up with any real wood savingsthank you sir.cleared up some questions i had
What stove is this?Don't know anything about your stove.
On my stove if I run with the cat engaged it's all good low and slow. I have to be careful about opening the air for more heat as it has a tendency for the cat to overheat. If I run my stove without engaging the cat I can run the STT much higher and get the room extremely hot but I am burning "dirty".
Ahhh okIs it not on the bottom of my posts? I have a VC Encore 0028.
A cat would be secondary burnmine is just secondary burn
First off my stove is OLD, it was the first experiment in catalysts for VC. I can run my stove with the bypass open and you won't be able to stand it in the house and my flue temps will be very high. On the other hand with the bypass closed and the cat engaged and active I could probably melt the back out of the stove with the cat temps. You'll see VC stoves with the fire back all warped from glowing red from the cat.And I thought there was a issue with running some VC stoves with the bypass open and running them hot? Something about destroying stuff in them? Im sure someone else can elaborate unless im losing my mind.
No I thought reading on here over the years others with VC's had issues from running with the bypass open hot. Might be other VC stoves tho. I dont really know which is which. Hence why I said someone else would probably have better info.First off my stove is OLD, it was the first experiment in catalysts for VC. I can run my stove with the bypass open and you won't be able to stand it in the house and my flue temps will be very high. On the other hand with the bypass closed and the cat engaged and active I could probably melt the back out of the stove with the cat temps. You'll see VC stoves with the fire back all warped from glowing red from the cat.
