Castle Serenity - Major Safety Issue on Fresh Air Intake? (Video)
JumpyHippo
1
chicago
I made these two videos to show what I am talking about. I called Ardisam, they had no solution. I even called Intertek, they have not seen this before.
The issue is not indoor humidity. It's at 45% in my basement at in the upper 30s upstairs where the stove is.
All comments, criticisms, skepticism, lauds, scowls...are welcome.
- Part 1
- Part 2 (most relevant to the point above.)
There are 2 solutions
One Use an exhaust pipe (chimney ) that has a built-in OAK
That way the intake air is warmed before going into the stove.
Two Don't use an OAK just use room air
Reactions: Ssyko and Washed-Up
awful long vid. May have helped if you would have used a proper OAK pipe with a proper wall exit and slight downward angle to keep moisture build up draining out, i do not imagine that loose fitting exhaust pipe is helping since it will not have a proper seal and will be both drawing in cool moist air from outside as well as warmer air from inside through the poor connections creating moisture.
  • [Hearth.com] Castle Serenity - Major Safety Issue on Fresh Air Intake? (Video)
