Casting Mark on Intrepid II
backpack09
554
Rochester, Mass
Are all of the Intrepid IIs casted with 1987 on the inside/cat of the stove? My brother is looking at one, and the only info the seller can give about the age of the stove is that casting mark.
The UL listing plate on the back of the stove has the date of manufacture on it. That 1987 isn't the date of manufacture, just the date the casting was first made.
The first run of Intrepids had the certification date 1987 stamped inside one should be looking at the label attached to the back of the stove
the very first ones were tested to Oregon specs. the next model run does not have 1987 stamped on then I think 1998 there after. Sounds like he has the first model run
same as I have
