Castile smoke leaking around vent pipe
ablejoy
I have a Castile stove that leaks around the exhaust pipe when it first fires up I get smoke coming out around the pipe . The pipe coming out of the stove. The exhaust pipe has been resealed twice where it hooks to the stove pipe. Have there been any problems with cracks on this stove. I can see the smoke just before the pellets light off. I am sure its not the connection at the exhaust pipe.
Thanks
Did you try to tape all the joints? If not get some metal tape and cover all seams in the pipe and go from there.
it is the connetion to the stove and the pipe use 2-3 times as much silicone as before it is very unlikely that there is a crack in the stove it is a sloppy fit depending on the pipe
It could also be leaking at one of the other pipes, or an elbow. The smoke gets into the outer wall of the pipe then bleeds back down to the open end where it connects to the stove.
Thanks we found the tee coming out of stove had a crack allowing fumes and smoke in the house just before pellets would light. Replaced the tee and stove working o.k now.
