The feed motor in my Castile stove has all of a sudden stopped feeding. I checked the vacuum switch fittings for blockage. I jumped the vacuum switch leads and it worked. I have no continuity on the switch unless I put heavy suction on it. I also checked that the exhaust motor was blowing in the correct direction and is pulling a good suction through the bottom of the glass door. The door gasket has slight fraying in the corner but has no leaks.
Does this mean the vacuum switch is bad? I heard that is fairly rare. Do I need to check something further? I am stumped.
