Castable refractory
mark123
174
PEI, Canada
Would castable refractory such as Imperial dry mix good up to 2100F be suitable for door lining of my woodgun. The material there now is a very low density material they call ceramic door board.
  • Castable refractory
Reactions: hobbyheater
Imperial castable refractory cement is a good product but it would be working right at its maximum rated temperature , Dukast 3000 would be a better product but it only comes in 55lb bags and north of the border is around$100 a bag . I would suggest that you try the manufacturer of your boiler for the piece you need it may turn out to be cheaper and more satisfactory .
If your talking about the upper door the Imperial should work fine , but not so good on the lower door!
