Can I get some opinions about what this seller of stoves says about cast iron stoves? Is this true? If not why would he print it?
http://firesideonline.com/cast_iron_stoves.asp
cozy heat said:Ya, this should be fun. Some people love cast stoves to death - so we're treading close to religion here. But search the forums - more often than not the words "cast iron" will be associated with 'cracked', 'broken', 'rebuild', etc. Cast iron certainly has it's place, but IMHO a bunch of loosely fitting cast parts, held together with brittle furnace cement, with fire inside, in the middle of your living room - isn't one of those places.
Not that improperly designed steel stoves can't crack either, but when my dragon is cranking 950F in the dead of winter, I rest much more soundly knowing there is solid steel welding holding the chunks together as opposed to some overblown caulking.
Slow1 said:Also interesting that the link OP provided says "not selling VC stoves" then lists three of them.. perhaps they are referring to other models not listed that they are not selling? I'm just confused I suppose.
4- finger- Pauly said:Can I get some opinions about what this seller of stoves says about cast iron stoves? Is this true? If not why would he print it?
JotulOwner said:My take is that the seller is pushing his product (steel stoves) and bashing everything else. I could be wrong, but, if I am right, that is some clever advertising. Anyway, I have a Jotul and never had one regret about making that choice.
4- finger- Pauly said:Do you have to rebuild cast iron stoves every so often because the joints start leaking air?
How often would a well made cast iron such as Jotul need to rebuilt if used correctly?
polaris said:How many quality cast iron stoves use anything other than rope gaskets? This steel stove pusher is a wealth of misinformation and my Jotuls and I take offence to it!
