Cast iron question
Ctwoodtick
2,145
Southeast CT
if cast iron on stove has slight warping that's occurred, does this typically get worse or can further warping cease if proper burning procedures are then used.
Thanks
It is hard to say. It could stop and never go further even if you over fire it again or it could continue to warp even if you do everything right. It is not very predictable
Is it your Jotul that's warping?
Its the Jotul I am thinking of. The front lip as seen once you open the door, has a very, very slight bowing effect outwards. I noticed it about halfway through last burning season. Took out a metal ruler, it's very very slight, does not appear to impact functioning. I gave the inside-and the part of outside that is visible with it being an insert- a look with flashlight and cannot see any noticeable warping or cracking...all looks fine.
Cast iron question Cast iron question I have added pics. I'm pointing to where you may be able to see slight bowing effect.
Lightened image Cast iron question
I don't know about the cast iron . . . but those hands.
I've never seen hands like these before. They're so soft and milky white. You know who's hands they remind me of? Ray McKigney -- the most exquisite hands you've ever seen. Oh, he had it all . . .
