I have tried everything I know except change the auger motor. When I'm burning I always run out of pellets. I have adjusted the A and B buttons which is the high low burn which is supposed to fix this. Anyone else have this problem? Thanks
I'm going to assume that you at least have pellets in the hopper when you run out of pellets in the burn pot so I'm not going to tell you to fill the hopper.
How about turning your draft down or closing the damper a bit.
You have to match your air flow to your fuel feed.
