After much research I found a lot of great info and tests for this unit, along with a user manual, circuit diagram and test protocols for various issues like mine, but even after those tests, I can't determine the source of my problems.
Symptoms: Turn on stove, circulation fan comes on but not the combustion fan. Auger works when manual feed button pressed. Pressing the auger button doesn't turn on the green light. Given that I had no green light/activated auger, yet the auger could be run by feed button, that indicated in the docs that this was likely a vacuum pressure switch issue.
Vacuum switch can be manually activated (pressing down the nipple that holds the microswitch open) and it also works if I suck gently on the hose creating a small vacuum. The vacuum port into the combustion chamber is clear, as are the chimney pipes and the combustion chamber is all cleaned out. The vacuum hose is good, though it has two round holes through it that look intentional, not a fault. Regardless, blocking off those two holes doesn't activate the vacuum switch.
I can bypass this switch and everything seems to work fine then, getting the auger green light as expected for normal use. So diagnosis seems to point to the vacuum switch, but testing it seems to verify it works. Is it maybe that it's not working well enough, that the vacuum is not strong enough for this old switch and I need a new one that's more sensitive? That's my best theory but I wanted to check here.
The part that really concerns me is that the combustion fan needs to be running to pull the vacuum, right? So what activates the combustion fan initially when the stove is turned on, so as to pull the vacuum that keeps it going thereafter? Shouldn't something else start the fan off? I'm not getting the combustion fan running (at least when cold) unless I bypass the vacuum switch.
Also, feels like the top auger bushing is missing or completely shot, as the motor can move/wobble about freely (should it be mounted to something?) . The auger still functions though.
Any advice is very welcome. My family are complaining about the cold nights!
I love this old stove and would like to get it working again.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
