Can someone identify this fireplace?
Sawyerlol89
4
Arkansas
I think it's a heatilator? Can someone provide me with the model of it? That steering wheel looking thing isn't attached to anything. I think it used to control a damper that is no longer there? Thanks for any help
  • [Hearth.com] Can someone identify this fireplace?
It may be an old heatform style fireplace, but some can be hard to identify. The damper chain may have corroded away and need replacement.
i think this is the damper? I don't know who removed it or how or where it goes. It may have completely rusted out I have no idea. For whatever reason they didn't put a topper on the chimney
Yes, it's a damper, but I wonder if it was replaced with a damper cap on the chimney top or not. If you shine a light up the inside of the fireplace toward the damper area, what do you see?
There's nothing on top of the chimney it's wide open. I see daylight when I look straight up the fireplace if that's what you're asking
I'm not sure why the damper was pulled. Maybe the pivot blocks had corroded?
