Can I oil a Harmon XXV combustion motor?
mrbean1025
98
Southern New Hampshire
I tried a search and couldn't locate anything on it. Last night I started hearing an odd noise coming from the combustion motor (I took the back off and it is definitely the combustion motor). It is not a high pitch sound and is not constant. I was wondering if maybe there is a way to oil it as something may be drying out. The stove was completely cleaned about 2 weeks ago with the motors being removed and cleaned as well.
Mine has sealed berrings(PB 105) and as far as I know sealed berrings cannot be lubed.. If they are bushings...my preference would be a graphite based lube.
I have the "sealed" ball bearing type motors in my stove, but always run some oil into and around them anyway. 4 winters on the motor and no noises <crosses fingers...LOL>.
If that doesn't help, and you're somewhat handy, you could take the motor apart & replace the bearings. Usually not too hard to find locally. (bearing supply.....Grainger, etc)
Reactions: iceguy4
My guess is your not getting the oil where it needs to go ...plus your adding something that attracts dust to areas where it can do the most harm...hence why I prefer graphite lubes...Dry graphite...No flame intended;em also replacing the berrings is an easy task for even the most un- mechanically inclined person.
Im with imacman. I've done my "sealed" bearings for 5 seasons in my Quad and no noises, sounds, or I'll effects.
The "seal" isn't a true seal. It's just a dust cover. It can be easily gotten around with a needle, or just put on the end and spun. The oil does get sucked in.
Use an SAE 20 oil (3-n-1 oil in the blue can, rated for electric motors) and it can't hurt. I do mine twice a year. Mid season and end of season.
