I have an old Beach Compeer cook stove, about 1914-15. I picked it up about 10 years ago. It has been sitting in my basement since then and last fall I decided to hook it up and burn a bit of scrap wood and split wood that I cut last spring.
My chimney was already set up with a stainless liner so I picked up some double lined pipe and got it going. It worked great but for one problem...it burns WAYYY too quickly! Even with everything closed down and burning hard maple, it is reduced to ashes in under 2 hours! The top is sucking air between the fire box and the oven main cooking surface and of course it sucks air like crazy behind the fire box door cover, through the ash grate holes and around the fire box door and ash box cover!
The "secondary burn?" holes on the side of the fire box is just a conduit for a steady stream of air even with the main damper closed! Does this system really work???
Is there ANYTHING I can seal up which will make this stove more efficient?
Any advice from seasoned pros would be GREATLY appreciated! I have some pics with the top off because I was considering sealing the main top with high heat caulking. Mistake? Let me know. Thanks
![Can I make my old cook stove (almost) air tight? Can I make my old cook stove (almost) air tight?](https://www.hearth.com/talk/data/attachments/293/293872-3cb4fef92ff54ba10f1390333bc0d712.jpg)
![Can I make my old cook stove (almost) air tight? Can I make my old cook stove (almost) air tight?](https://www.hearth.com/talk/data/attachments/293/293871-06fb589de311210d5ede2efad48b662b.jpg)
