Can I do this...........
WoodMann
670
New Mexico
Right now I have double walled stove pipe. Nothing's wrong at all. So why fix it? Thing is that I can't get a proper reading of the flue tempwith the double- walled stove pipe, so I was thinking of putting a single wall peice in for like the first 18 inches or so. Is it even possible to mate single and couble walled pipe..........
I believe once you start with the double wall, you have to continue with it till you terminate.
What about a probe thermometer for that double wall pipe?
Why not go by stove top temp?
I second that, just buy a Condar probe thermometer. They cost like $20 and only require a small hole and your done installing it.
(broken link removed to http://www.condar.com/meters.html)
You really can't transition from single wall to double wall and then back again. I've tried. Don't do it. Just spend the jack for the condar probe thermometer; I've got on on my single wall pipe, can see it from the couch and love it because it's actually telling me the flue GAS temperature (interesting) rather than the single wall stovepipe surface temperature (not interesting).
I do just that and it works great. The only thing you need to do is remove the thermometer when you are cleaning your flue. I have the Condar probe thermometer which I bought directly from Condar.
Jay
Wow- a probe thermometer, didn't know such a thing existed. Alot easier than wrestling with single and couble walled stove pipe. Thanks........................
