can I add wood with an active cat?
Absolutely. Open the bypass and turn up the thermostat. Wait about 2 min. Open door and add your load. Close door and let char for a few min or as long as needed. Relatch the bypass. Continue on high burn for a few more min. Slowly start to dial back your thermostat to desired setting.
Yes, I do this at least 2x per day. Open bypass damper several minutes before opening loading door, to give the cat every best chance to cool a bit before slamming cold air upon it.
What they said.
About 99% of my loads are done this way.
Reactions: Pinesmoke
