This is mostly a matter of getting someone to check the calculations (esp. if you've done similar calculations yourself).
I'm contemplating installing a gas stove as a part-tim space heat option in a cold corner of the house. At the maximum, I anticipate maybe half a million BTU's per day. So half a million BTUs of NG makes .02 lb of CO and about 60 lb of CO2. Of course, the regs are all concentrations by volume, so I convert that over to about 13.5 m3 of CO2 and about 8L of CO (0.0079 m3).
I figure the house is 2400 sf, with 8ft ceilings makes it 19200, or 543 m3. so if there's no turnver of air, after a day of burning flat out, I'm at 0.000014 (14 ppm) CO, but 0.0248 (24,800 ppm) CO2. Regs are 35ppm CO and 800 ppm CO2.
Do these numbers seem reasonable?
Thanks
Steve
Thanks
Steve
