Calculating overheat dump zone
horrocksd
42
Finger lakes, NY
I'm trying to calculate how much fin tube I need for my overheat 'dump zone" for my Econoburn 150 installation. It looks like I need to have at least 10% of my boiler capacity which is 150k BTUs, so I need at least 15K capacity in the dump zone. I have a bunch of old 3/4" standard domestic fin tube in good shape that I'd like to use for this. Can anyone give me a ballpark idea of how many BTUs per foot this size fintube will provide, or do I really need to know pipe i.d. and o.d., fin size and spacing, etc?
Also, is this size of fin tube adequate for a dump zone or do I really need to go to a larger diameter? I'm just trying to control my costs on the install without cutting any important corners. As always, thanks so much for all the great info I get from everyone!
500 Btu's per ft . I just use my whole basement zone . I dont have seperate special dump zone set up .
I used 3/4" for my dump zone. I have the zone valve open when the boiler goes into idle do disappate the heat so it won't idle that long. It seems to be working well for me. I wish I had used a little more though, just in case.
If you're building from scratch just run them in parallel.
--ewd
Eliot,
Thanks for the reply from a fellow mid-stater! I'm pretty handy with cars and construction, but am new to boilers and hydronic systems. What do you mean by running them parallel?
Feels more like Hudson Bay today.
Just like a radiator, if the tubes are individually too small put a header/manifold on each end and run the tubes in parallel.
