buying a used Vermont casting Intrepid 1302 or Jotul#*???
Kenneth
2
Central Missouri
High all I'm new at this and I;m thinking about buying a used Vermont Casting Model 1302 Intrepid. Over the last few days I read a lot about stoves and it is very confusing. can anyone that has or has had a intrepid give me some help.
I'm also looking at a never used but about 25 year old Jotul #8 any help there. I'm heating about 950 SF very old house no insulated walls brick on clay tile and plaster.
Thanks Grayone65
if its an old non insulated house you need lots of heat....
the 1302 is a nice small easy to maintain and operate useful stove. But it is small.
If the house is small, then a 1302 will be fine.
if its bigger than about 1200 SqFt and no insulation you're gonna need a bigger stove.
I dunno nothing about a jotul#8.
I heat 1400 sqft with an intrepid 1302 but the house is insulated, not very well but it is. The temp here rarely goes below zero.
often I have to open a window, even in the dead of winter.
The size of the house will dictate the size of the stove needed,
If that Jotul 8 is still available, please pass the info on. That's a nice stove and some came in catalytic versions.
