I'm having an issue with hard to control fires in my stove. I'm new to wood burning and installed a Regency F2400M, a very standard steel, non-cat, medium stove  with about 15 feet of chimney straight up.
I've been trying to get overnight burns by loading the stove full and closing the primary air all the way down in stages . The problem is that even when the primary air is fully closed, with a full load the fires would go out of control and stovetop temperatures would start climbing above 850 degrees.
To help this issue, I installed a flue damper to control the draft. It helps, but the only way that I seem to get a controllable fire overnight with a full load of wood is if I shut the primary all the way AND shut the flue damper all the way (it has some holes so it doesn't seal the flue completely). If I leave the flue damper even slightly tilted open, I'll get big flames and stovetop temps going above 850, still.
This seems like a crazy amount of draft to me! I think I have a very typical, by the book, stove setup. Does anyone else experience similar issues? Is it safe to burn overnight with the key damper fully closed? Does anyone else use the damper like this? Thanks a bunch for any help.
