sparke said:
Hello, My first post here. Nice place
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Ok to my questions, I have a Buderus Logana add on boiler. It is rated to burn wood or coal. The boiler DOES NOT have shaker grates. The manual says that you are supposed to use a riddling tool (which I dont have and Buderus doesnt sell anymore). Everytime I try to burn coal, I fail miserably. At the end of the day the coal never fully ignites and goes out leaving almost full size clunkers. I use a 1/2" tubular shaped tool with a 90* bend on it to riddle. The boiler has holes at the bottom of the coal bed which to insert the tool. I run the tool horizontally on the grates until I see red coals start to drop.
1. Is it feasible to burn coal in this boiler with out shaker grates.
2. Possible low draft problem?
3. Open secondary draft (located above coal bed on the door) more?
4. Different ridding tool?
5. Is the poor burn a result of not shaking (which I cant) or ridding wrong??
Thanks for any suggestions.
Well, I was going to delete all the other answers, but I will wait - at least a few minutes!
This is a GREAT coal boiler, and is in fact designed more for coal than for wood. It is a updraft, cast iron unit very similar to the SIME boilers, which are now imported under another name.
Many of the best coal stoves in the world, including early Efel and Surdiac models, have no shaker grates. The Buderus has "wet grates", meaning water running through the grates. Not only does this transfer heat best, but it also makes for less clinkers (fused ash) because these form when coal is too hot.
OK, so we have that out of the way...
Yes, it is very possible you have a draft problem. Read the sections on Hearth.com about chimneys and also about staring and tending a coal fire. Also read the one about hopper-fed European stoves (for shaking techniques).
Tell us about your chimney situation.
I had a SIME in my house and my 2 story chimney was too weak. I installed an Exhausto fan on the top of the chimney and solved that problem. However, you might try the draft basics before this (make sure pipe is tight, chimney clean, etc. etc.).
If you can easily start the fire and get it going then your problem might be shaking technique. Here is a hint - if that boiler does not smoke out the loading door when loading with wood, chances are your draft is decent!
So, you start up the fire with some small hardwood, get a good bed of coals and then throw 5-10 pounds of coal on top. Make certain the draft control is full open at this time. When the coal is definitely lit and going, throw another 5-10 pounds on. When that is lit, you can fill the stove with at least another 30+ pounds. If you do not have a deep bed of coal, it WILL NOT WORK.
Raking is done by using a poker or large flat tool as close to the top of the grates as possible - thru that little gate in the front of the coal fire when the bottom door is open. Rake or knife until a bit of red drops through the grate.
Remember, the boiler will not work well in warmer weather - wait until below about 40 degrees if possible.
