This should be a quick fix...famous last words I guess.
Heatilator - NDV3630I
Everything was working fine, my fan control module was just stuck at the lowest speed so I ordered a replacement.
After replacing the fan controller, the burner won't light. (blower works great now) Pilot comes on when I flip the wall switch but no burner start. It's like the burner valve suddenly stopped opening.
It must have been something I did, but I can't figure it out for the life of me. This is what I've done so far:
1) I put the old fan controller back in - no fix, same issue
2) Pulled the wiring harness off and olhm'ed out all the wires - all good
3) Looked up the olhm values for the pilot and burner valves (I think I found the right values on the net) - both good
4) I thought, maybe I damaged the main Dexen controller somehow, so I ordered a replacement - same issue
Is there something I can jump to test? It looks like that wire coming off the controller to the burner valve is negative. Does it get a ground?
What am I missing? It was working no problem. My wife is starting to doubt my abilities. Any thoughts would be appreciated!
Charlie
Charlie
