New Ravelli RV80. Installed 2/4/22. I bought it to replace a nearly 14 year old Avalon Newport.
It's been a great little stove so far. So much quieter than the old Avalon and rated at about 7,000 BTU more. I have a small home and it takes care of things nicely. I have it pretty much figured out, still learning little nuances and idiosyncrasies here & there.
The installer said it should be cleaned once a week. The ashpan could probably handle that but I don't like the amount of ash I see on the grate that surrounds the burn pot or that falls from the heat tubes above so I stick to every 3 days, sometimes 4.
One thing I notice is that after 2 to 2 1/2 days there's a hard buildup about 3/4" thick on the bottom of the burn pot. Of course this causes the pellets to come right to the very top of the burn pot, almost overflowing upon restart. Photo attached. I've taken to removing the burn pot and knocking this out on Day 2 of burning the stove after a cleaning.
This process appears to be accelerated when in Eco Stop mode where the stove turns on and off when the specified room temperature is reached. If the stove is in steady burn mode it seems go longer before this occurs. With fluctuating temps lately I can't run in steady burn, as the room heats 18 to 20 degrees higher than the set temperature when it's been in the mid to high 30's outside.
This isn't a major deal and is easy enough to deal with. Just wondering if anyone else with a Ravelli has experienced this and if so, have you found a better way around it?
![Burn pot buildup Burn pot buildup](https://www.hearth.com/talk/data/attachments/293/293379-215355d252b567f802fc89c625c1e940.jpg)
