What's a reasonable expectation for temperature drop in well-insulated buried lines? In this case, we're looking at 150 feet or so, with 3-4gpm average flow.
In my experience, using Thermopex with my OWB, I would think anything over 3-4 degrees would be unacceptable.What's a reasonable expectation for temperature drop in well-insulated buried lines? In this case, we're looking at 150 feet or so, with 3-4gpm average flow.
The return might be heated by the supply line losses warming it as it flows back.
i was just going to post this same question. I noticed my system not performing as usual. checked output temp of 170 and 150' to the house the temp coming in was 160. so I am losing 10 degrees one way. system is about 8 years and in years past I have seen about 2 to 3 degrees drop. I am 6 feet down with 2 inch pink homemade box insulation with divider in between.
a dig up is not on my horizon. time to rethink this thing.
Well at least it's not warmer than when it left the house which would indicate X talk.The return line shows almost no drop
Or this. The insulation between the two pipes has failed. Time to dig it up.
It is water resistant but not water proof. There are plenty of online references. If subjected to submersion or 100% humidity it will eventually fail by absorbing water. Every hot tub owner knows this lesson as we typically have to replace our waterlogged closed cell foam based covers every 5 years or so. Open cell foam is obviously a poor choice in this application.Does SPF absorb water?
Closed-cell foams, by nature, are resistant to water absorption, and are approved by FEMA as a flood-resistant material. Open-cell foams can absorb and retain liquid water at varying rates. It is important to consider the different properties for each foam type for each application.
