Hey guys,
Trying to get out in front of my project this year before it starts getting cold unlike last year. So for reference I installed a stainless liner with an Englander 32-NC last year. I did not start using it until we were halfway through the burning season or so. This picture is the horizontal run between my wall that connects my wood stove and chimney. I don't know how but this buildup looks worse than it does on camera. Does this look like normal buildup for something that I did not even use for half of the season?
Also we thought that my woodstove may have been getting hotter than normal. I do think some of my wood had too much moisture in it but I know a lot of it was dry. The dry pieces obviously burned a lot better but it did seem like the fire 'got away' from me much faster. As in even with the stove locked down it could burn pretty hot. Not sure if this could have contributed to the buildup or not but thought I would mention it. I am considering adding a damper somewhere to get more control. I may leave it out for now though because I realize I am still learning this stove. I moved from an old Huntsman I believe was made by Fisher and this has been quite the adjustment. I went into it prepared because of this community.
Finally if you guys also have cleaning recommendations I would like to hear those as well. We have always cleaned ours from the top down. Now that I have the stainless liner I may like to go from the bottom up. The only thing is, my horizontal run is about two and a half feet long before it meets the vertical tee. I think the Soot Eater things that look like string trimmer line get good feedback here. I'm not sure it is going to work well for me if it has to go that far before it bends?
![Buildup Normal for Stainless Liner and Cleaning Recommendations? Buildup Normal for Stainless Liner and Cleaning Recommendations?](https://www.hearth.com/talk/data/attachments/328/328477-a4db4fcb860e35d22341c89bf3590a92.jpg)
