Hi folks,
Father-in-law is almost done building a nice, new splitter, but we have a couple of questions.
Have a Haldex-Barnes 11gpm 2 stage pump, with a max working pressure of 3000psi.
The 3.5" x 24' cylinder has a max pressure of 2500psi.
Questions:
1. Does the pump have an internal pressure relief valve, that will protect it, if something were to block downstream, so to speak - so it will not blow the side out of the pump?
2. Using an old spool valve, from an old log loader, that has an internal, adjustable pressure release valve to control the flow to the cylinder. Should we adjust this to 2500psi, as the pump is rated higher than the cylinder?
Thanks in advance for any help!!
Questions:
