Now I found the right name for this...
Any tips to build one?
I split a bunch of log ends last year (when you don't plan on the bucking and wind up with longer than 18" splits
) that are just too big for my wood stove, even when loaded diagonally so I am going to have to cut them again... And I figure I'd like to build a saw buck with 2x4s, similar to the steel design above, however, I like to have the length adjustable, just in case. Do you think I would be better off making an adjustable one or just make two?? I figure if I use a 2x4 as the length supports but make holes in them at various lengths I could make it adjustable (to a point), at the expensive of some stability. I could use long bolts and nuts and washers to move the ends closer or farther based on the length.
Or do you think it would be easy enough just to make two sawbucks that I could use on longer lengths? and just one for the long splits that I need to cut again... ??
Thanks for the suggestions!
Jay "the thinker" H
![Building a sawbuck Building a sawbuck](/talk/proxy.php?image=http%3A%2F%2Fwww.baileysonline.com%2Fprod_images%2FSB1500_L.jpg&hash=0325a690da38ae929bd77bf902a7d7e1)
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Jay "the thinker" H
