The burner has been installed & it's time to start the finish work.
The stove is a zero-clearance insert-type Bis Tradition CE. The top, bottom, both sides, & back of the unit are not an issue. The only non-combustible finishing I need to do is the hearth and facing around the unit. This will be done with Durock. The pic attached is a rough mockup and what I'll be building. The yellowish? area on top is the ceiling. Basic dimensions are 6 feet wide, about 11.5 feet on the left & 14.5 feet on the right. Vertical surfaces will be dry-stacked slate, horizontal of the hearth will be slate tile.
The hearth will be 6 feet wide & about 10 inches high. The hearth assembly I'm considering is below. It'll run around 220 pounds. It'll give me an R value of 1.56 (all the Durock, not counting the slate tile). The Durock layers will be screwed together with 1.25 inch Durock screws & Flexbond thinset. The stove manual only states the hearth must be a non-combustible surface....no R or K values given. The stove puts out a max of 55K Btu with a contiuous output in the 30-35K Btu range. What do you think...is this a sound approach?
Stove front
slate tile (0.375 inch)
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
24 ga galvanized flashing under stove & fully covering hearth area
0.5 inch Durock
6.75 inches dimensional lumber 2-by
subfloor
![Building a hearth...does this seem reasonable? Building a hearth...does this seem reasonable?](/talk/proxy.php?image=http%3A%2F%2Fusers.wi.net%2F%7Edatuboat%2Fimages%2Fmockup1.jpg&hash=6ab92f977afcd8969a563c0694c75e3b)
Stove front
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
0.5 inch Durock
subfloor
