I was going to makes a little build log with pictures and update as I go. This is my first wood burning stove/insert so any feedback is greatly appreciated.
Already made my first mistake and ordered a 6 inch liner for a ~6.5 x 11 opening. Got a 5.5 on the way. It is a pretty clean chimney. Not a ton of extra mortar overhanging and it is a straight run. I'll ovalize if needed.
The house was built in 1977 and we only used the fireplace no more than 10 times. Some of the mortar was cracking and air was getting inside. I removed any loose and/or cracked mortar and repaired with high temp mortar.
I have a sawzall ready to go. The previous owners barely used the fireplace. There is a little buildup by the damper and very little at the top. I have a brush and cleaning rods on the way and will scrub the above the damper with a wire brush.
I ordered some CrownCoat. I'm not sure, but it looks like the lip is brick?? Then it has a mortar run off on top? Not sure the best way to repair it. If I need an entire cement crown, I might have to wait till the spring and I would try to get away with sealing it for this winter. It depends on the weather.
I received the insert today. It has a dent on the back so I am not sure about asking for a new one. It doesn't look like much, but that is pretty thick steel. Is there anything behind that? It looks there should be a gap before the fire box correct?
Question about the bricks.. Why is there a gap in the manual between I and J? I though it was for a hole to a sweep out or something but the bottom of the firebox is completely flat. All the old wood stays on the bricks and you have to clean it out from there? I only received 30 bricks and it shows 31 if you include I and J.
![[Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair [Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fith0SGg.jpg&hash=8bea4d2be12d0705215419b58f16ef97)
![[Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair [Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FISPcSX3.jpg&hash=4e2097d185cdd4dd3b4ef0c6a5b6aeb2)
![[Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair [Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FbDuz0M4.jpg&hash=cd8b9133f54f4c10fd193aacc5027d0e)
![[Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair [Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FcTIBldo.jpg&hash=569bf3092009a1c1a5b5c4402535918b)
![[Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair [Build Log] Napoleon 1402 + liner install + sheet metal damper + crown repair](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FhFrdrQa.jpg&hash=f27f372de89727f4be2730f3777915b7)
