Newbie here. [Wave]
Buck 91 insert was in a home we purchased 2yrs ago, and we’ve used it the past 2 seasons. This forum taught us everything we thought we needed to know about using and maintaining a catalyst wood stove - never had one or used one before we bought the house. Seriously, this site is/was a godsend.
We were meticulous about dry wood, opening/closing damper, correct temperatures, etc after reading posts here.
This Spring we decided to do some maintenance since we have no idea about the stoves history or previous use - the house was abandoned for almost 3yrs, and PO skipped state while filing bankruptcy.
Buck actually updated their manual for the 91 and it shows the catalyst location and replacement, so I dug in only to find - see photos!
NO lower cat shield.
NO catalyst.
Catalyst housing held by 2 nuts - there’s 8 bolts.
(I have more photos.)
We’ve purchased the catalyst and gaskets, and are about to order the other necessary parts - cat housing, brass nuts, lower shield, etc. I sent these photos to a dealer who said they didn’t look too bad. I sent them to Buck who said maybe 2 seasons. The photos are looking through the door and up at the top of the firebox where the cat housing usually is, the bolts secure the housing to the top of the stove. There are cracks at 6 of the bolts I believe, and “bad?” cracks at the two rearmost corners.
Please flood us with info and options; is the stove usable, is it trashed, can it be repaired, should it be repaired???
Thanks so much in advance, and again for the knowledge gained here to even know how to get this far!
NO catalyst.
