If my stove is rated with a heat output of 10,000 to 36,000 per hr, a 2,221 square feet home, what calculator would you recommend to see how cold it would have to get where the stove would need help. Also is the calculator results per hour?
There are many factors that go into a heat loss calculation. Fill in what you can in the light blue boxes in this calculator and see what comes up. For an old house like ours with too much glazing, I'm estimating it would be around 20ºF.
Yes you got it. I’m running the F3500 primarily and looking for numbers when to run both. This is what happens when I have time on my hands and I’m geeking out.
What’s confusing me is all the calculators online show results of 88,000 to 111,000, the F3500 is 36,000 BTU hr. I know with outside temps in the 20sF it has no problem heating the house. Can’t be that 88,000 to 111,000 BTU is per hour.
If it ever got down to zero here (never has) then we would be underheated for sure, even with the T6 cranking its heart out. Up where you are that is not uncommon, right?
Last year we hit a windy 2 degrees and I ran both stoves, but stupidly ran both completely full but low and it was chilly in the house. I should have opened them up. Was trying to see how both would do on low.
Your 88,000 per hour capable furnace is outputting that 88,000 per hour intermittently. Rarely would it be tasked with staying "on" for a whole hour even though it is capable of it if the J load was calculated correctly. Although I've seen homes with gas furnaces that were a little undersized by builders to keep the price down and gambling on rare cold weather. AT least with a wood stove you can all hole up in the stove room.
In the winter teens and 20s is common temps, we usual get several days that could hit single digits, we have hit 0 and slightly below. Thank you for the calculator love it, was taking all the measurements has my wife is looking at me saying only you why am I not surprised . In the single digits to 0 I would definitely need to run both stoves full throttle, I was coming up with 64,000 btu at 0. Again thank you.
