I am looking at 2 enviro inserts. The ef3bi or the meridian. The first says 40,000 btu the second says 45,000. Is there a big difference. Also they dont say the come with a thermostat. Do they just run all the time?
You can put a thermostat on the Meridian and run it in on/off or hi/lo mode. I believe the EF3 can have a thermostat but it is strictly hi/low. 5k btu's is 5k btu's. I'd start by figuring out how many btu you need to heat the area you want to heat.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
