It must be the winter of the original Defiant — I've noticed a few other people have recently moved into places with these stoves.
My situation:
I'm renting an old cabin in a small town in Western Montana, about an hour east of Missoula. Since I don't own the place and won't be here for much more than a winter, it's not really an option to get a new low-emission stove, which is what I certainly would do if I owned the place. The stove seems to have a number of problems, and I could see rebuilding it, but again I don't own it and it's probably not my place to take the whole thing apart. Of course, if the stove has some serious problems, then I may well be able to convince the person I'm renting from that it needs to be replaced or repaired. But generally I'm looking to figure out how to make do for the winter with what I've got.
Here's a couple pictures. It looks to me like the fireback is cracked:
Am I right, is that a few cracks through the fireback? How serious a problem is this? Once I get it up to about 550 degrees I've tried turning down the damper, but it doesn't seem to be able to hold the heat, and while I don't see smoke the house seems to smell a whole lot, to an unpleasant degree.
This may simply be because it's not cold enough out yet and there's not enough draft. Or it might be that the secondary system is plugged up. I have also had some trouble getting hot fires going — I have to leave the doors open to get enough air in there and even then the stove seems to stall out at around 350. Is this just normal with these old stoves, or should I try to clean out the main air intakes? I can get it up to about 700 eventually, but this takes a fair amount of fussing. I'm using seasoned softwoods from around here.
As for the secondary system, maybe i should just wait and see if it'll work once it actually gets pretty cold out (been in the twenties at night lately). If I do try to clean it, what's the easiest way to go about it? Just take the stovepipe? Sorry if this is ignorant, but how would I go about that? Should I have some furnace cement before doing it, so I can put it back on? Would it also be worthwhile to take the top off? Or should I just give up on the secondary system, since the fireback's cracked and a complete rebuild is unlikely, and plan to run it in updraft mode through the winter? Maybe that's not realisitic — I really don't know.
Sorry for all the questions. Obviously new to wood stoves. But really enjoying it. Any advice would be extra helpful — and thanks so much for this site!
My situation:
