Broken fireplace rack where I place my wood
Akphillips
9
Denver
Hi all. I'm new & it's early in denver,, so I forgot what this item that holds our burning wood is called. what is it?
My q is -- why did the top threaded metal pArt of it break after 1yr of burning est 1cord of mixed hardwood & 2x4 starter? Some 2x4's had nails, but I read on here & my fireplace cleaner guy said it was ok to do so.
If it matters I got it at home depot or lowes & I admit that the metal felt lighter than my old one that the heavy metal broke on after 20? Yrs.
Thxs all!
Fire burner Amanda in Denver
"WINTER IS COMING" ha
I used fire dogs in my last stove. Made them out of railroad spikes and every year one of them would break in the middle. I'd reweld it, throw it back in the stove and be good for the season. Worked better than any grates I'd used previously.
Buck Stove still sells them.
(broken link removed to https://www.buckstove.com/partsstore/home.php?cat=21)
Reactions: Akphillips
Fireplace Grate
They don't make them like they used to. Most of us don't use them anymore.
(broken image removed)
Yes! A grate! Duh.. Thank y'all so much for ur answers. So there isn't anywhere to buy a good ole heavy duty grate like the one in this pic? My good old one looked just like this.
So if I don't have a grate under the fire how does enuf air get under the wood to start The fire?
Lastly, I suck at construction stuff so will u please explain how I'd make the railroad spike grate? That sounds cool.
Thxs guys !!
I just read the fire dog link .. Thxs a mil.. This sounds like what I needs
How much wood do u burn every yr?
post allot and your ranking goes up. And no the nails are not doing it. It will get enough air with no grate or andirons it will burn slower from the top down. You can always look at flea markets or consignment shops for a set of andirons or an old heavy grate.
Guys, last q-- how do I add "master of fire etc " below my name?
Your title will change the more you post.
I believe once you've mad 250+ posts it will change to "Feeling The Heat"
500+ posts "Minister of Fire"
Thxs so much. I'll ck craigslist too
i was burning threw one of those home depot grates in less than one year. i then bought a more expensive one online. same thing as the cheap one.
my final fix for it was to throw it out and i bought an insert. haven't needed one since
What are you burning in? Open fireplace? If a stove you don't need a grate.
What is an insert? I have a wood burning fireplace
Btw , I thought that ur pic was a face covered in black. Ha
