2 months ago I removed an old 4.0cu ft wood stove insert out of a house that was about to be demolished (free!). I've since put a little money into it re-doing it, getting the rust off accessorizing etc
. Anyway when I got the wood stove it only had 6 firebricks along the bottom of the firebox. I've since added 12 bringing the total to 18 and have another 6 on order. I made my relatives pay for their thanksgiving dinner by heaving this thing up on to the hearth so I could install it. Anyway the 18 bricks only line the inside of the firebox about half way up the inside of the firebox vertically. In this configuration I've not been able to get this stove over 550F going full bore while burning 1.5yr old Cherry. In general it seems to be running between 300-400F on average. I have a lot of experience with these insert type stoves from one my parents had when I was a kid so I know how to operate it such that it gets hot. I'm thinking the primary reason it isn't getting super hot is because there are no firebricks lining the top of the firebox and that a lot of the heat is escaping right out the top. The old stove my family had was completely lined by comparison.
I have more bricks on order however there is no hardware inside the firebox to hold the bricks to the top of the firebox. Would it cause a problem or provide any benefit if I just laid the new bricks on top of the outside of the stove behind the surround just leaving a little patch in between them so they don't block the damper rod instead of inside the box? Or is there some other way to mount them to the roof of the firebox? I could in theory weld some angle on myself, but this thing is a bear and a half to move and I really don't want to fill my house with the smell of burnt metal.
Also does anyone have any idea who makes this stove? It seems fairly old, certainly isn't EPA certified, but it has no markings on it anywhere. Here is a picture:
I've done some things to it so that it no longer looks "stock" the way it did when I got it which may cause it to be misidentified:
-I added the coil handles myself and the damper handle
-I replaced the steel plate in the door with glass.
-I put new screening on the blower
-Originally the surround was welded to the stove itself in two places.
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
![Bricks on top of wood stove insert... Bricks on top of wood stove insert...](/talk/proxy.php?image=http%3A%2F%2Fi58.tinypic.com%2F35kk0ok.jpg&hash=d75f2ffa8c33183b581d5e489b9ebaa6)
