Breckwell P24 Insert light keeps flickering/blinking?
adamztoyz
33
Western New York
This is the second season with the Breckwell P24 Insert which is a 1994 model. It runs great, but I have noticed the last couple of days the green light for the auger is flickering at times and seems to go off for a second. Is that a control board issue or? I tried to look at the manual and it appears it may be losing power to auger when the green light goes out. Any help would be appreciated before it gets cold. Thanks
The air pressure switch is losing vacuum. Clean the combustion fan chamber and clear the vacuum hose from housing to air switch.
Pellet Stove Controller Board-Repairman
The auger light will glow every time the board sends the auger power. It does not mean the auger is working such as an auger jam, just that the board is sending current to the motor.
Eric
