OK, I have read the other Breckwell convection posts here but my problem is a little different. When I start the stove, the convection fan willnot start blowing on its own. I always watch the stove pretty closely when starting. The stove gets pretty hot but I have shut it down each time before it stops on overheat. If I increase the feed rate OR hit the high fan button the convection fan will start running. Then I can lower the feed rate or high fan setting and everything is fine. I cleaned the stove one ton ago, but not the conv fan. I'd like to fix the problem before I clean it and shut down for the summer.
Thoughts?
Thoughts?
