My stove was working fine when the blower motor went out. I replaced it and the auger because I had replaced the auger a year ago with a cheaper one and every time it moved it sounded like baby goats. Now, everything works except the fuel rate won’t change. The control panel changes the lights from 1 through 5 on manual or 1-4, 1-3, or 1 on the high/low setting. I have bypassed the POF, high limit, and the vacuum switch and it still changes the lights on the control panel but does not change the auger speed. It goes off every 13 seconds no matter what it is set on. The high fan speed switch works. I have completely cleaned the stove every hose, tube, tray, and all concealed areas. Emptied all of the pellets out and ran the auger and vacuumed it out. Completely cleaned every crack and crevice of the stove. The vacuum tube is clear. I hooked the old auger up to it and the same thing. It only goes off every 13 seconds. Needless to say that it won’t sustain a fire at level one or every 13 seconds. Not sure what else to try. The control board works as it should. All fans work, the auger works, all airways are clear, all switches are currently bypassed and it still doesn’t adjust the fuel feed.
Any help would be appreciated.
Yes I have a manual and have read it multiple times.
Thank you.
Thank you.
without being there
