Breckwell p22 problems
PELLET PUPIL
2
CT
Brand new breckwell p22 FS
just installed
flashing number 3 light, and yes there are pellets in the hopper
wont ignite now and when i light myself it seems to stop feeding pellets within 5 minutes
I have noticed that when first turned on it will light up the heat level after about one minute
I dont think it did this before it only switched to the desired heat level once the fire was started
It seems to me from reading the manual that if the combustion blower fails it shuts down the auger
The combustion blower seems to be working fine
Could it be the hight temp thermo disc or the control panel. Should i try bypassing the thermo disc
ANY SUGGESTIONS??????
just installed
Not an English Major but, got some issue with periods? Just kidding. (note period).
Call me on Sunday morning after 10:00 I should be in depending on the ice storm hitting or not, 330-876-0200
Eric
THanks Eric for the great help.
I still cannot believe the bow in the stove.
Just out of curiosity was the stove you had encountered with the similar problem blinking 3 or 2.
THanks again.
I really appreciate your help.
THanks again.
That stove was 3 days old and still ran but the owner saw the bow which caused an air leak.
Good luck with it and let me know how it turns out.
Eric
I have the exact same problem and it's driving me nuts! :-)
Eric, would you mind posting here your solution to the problem?? (yes, I'm begging!)
Many, many thanks in advance!
Arnold
Arnold
Contact your dealer. It needs to be returned.
Eric
