well, I got my stove up & running after thecircuit board & combustion fan failure now the fan does not run @ high speed when I put the mode to 4 or 5. it stays the same rate. the pellets feed longer & fire gets higher but the blower fan does not kick up like it used to. I bought a new circuit board & replaced it along w/the combustion fan sine my original issue was that the fan ran constantly even w/unit off. so a little diagnostic work & long story short, burnt out original fan & board. now the unit works well, shuts down as it should but the dam convection fan is giving me concern, I do not use thehigher speeds much but I so not want to take a chance & need it & have it not work.
I am running my stove 24/7 now as main spurce for heat w/ electric baseboards as supplimentary.
any ideas on were to look for this isssue? could the replacement circuit board be bad?
