My stove seems to only want to run on setting one. When I woke up this morning the pellet feed rate was feeding at the setting one rate while the stove was set on two. Changing the setting to setting 3, 4 or 5 had no effect.
I opened the door and let the air flow switch trip to shut down the stove, shut the door, restarted the stove and it started feeding the pellets at the setting two feed rate as the stove started up. After not to long, the stove returns to the setting one feed rate regardless of the feed rate selected.
Stove has been cleaned regularly. Both the combustion and convection fans have been replaced this winter with aftermarket Fasco fans and the stove has been running fine until this morning.
Any starting point for trouble shooting this would be appreciated.
Thanks
Tom
Thanks
Tom
