Well, picked up a used Big E for almost nothing...came with the twelve feet of exhaust, and everything. I got it installed over the weekend, only thing I haven't done yet is install the OAK. I am having some issues... and I have a feeling that the crowd may be able to help me solve things a little faster, as I cannot find an installer in the area that will come and look at it for me.
My issues are as follows:
When I plug the unit into the wall, the blower for the heat exchanger turns on immediately, even before I turn the unit on via the button on the control board. Once I turn the unit on, the blower remains on for several minutes, and then turns off. The unit operates as it should as far as burner and exhaust go, although the exhaust tubing certainly gets hotter than I expected it to, inside and out. However, the blower for the heat exchanger NEVER turns back on while the unit is in use. The auger drops pellets in every twenty to thirty seconds, you can hear the exhaust blower going, and the burn chamber doesn't fill with smoke, so I know it's all working appropriately...but the only heat that is being produced is the ambient heat I can feel within 18" to 2' of the unit itself.
Now, when I turn the unit off with the button on the control board, after a while, the blower will kick back on again, and it will kick on and off intermittently as long as the unit is plugged into the wall...but NEVER while the burner is in operation and a fire is going. Can anyone PLEASE give me a recommendation? Thank you![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Rich
Rich
