GVA said:
Gooserider said:
It is one of those things where I find alot of people coming from an electrician background have a terrific understanding of how to run wire, but not a great background in how some of the parts work internally. Folks coming from an electronics background tend to be the opposite - I've had to do a fair bit of study to get to the moderate level of electrician skill that I have, and still tend to work with frequent references to my code books. Gooserider
Now that the forum has wound down a bit I reread this post........... Is this part a dig???????????????
If not disregard the following.
I hate pissing contests as to knowledge of electrical/electronics....or anything else
I can
run more than wire I used to work on solid state, 12vdc logic, TTL, PLC's and all that crap but I'm just trying to keep it simple here, you may want to keep it the same here too, I'm not gonna go into much in depth here but your description of a GFCI measuring HOT vs Neutral is misleading. Current going out vs current returning through the neutral would be a dead short.
Reread the thread I was Basically saying that pellet stoves like to switch neutrals and GFCI's do not usually like this............and neither do I.........
Have a Pleasant evening!
It is not and was not intended as a dig, merely a comment that the two areas appear similar but have different focus areas, just as different specialties do in other fields. My ET school pretty much stopped on the AC side with "It comes out the smiley face on the wall" but spent all sorts of time on the way electrons go through transistors. The electrical books I have all concentrate on proper wiring practice and technique, but do as little electrical theory as they can get away with, including treating stuff like GFCI boxes as "black boxes" that just work, don't worry about what's inside. I had to do a lot of independent study to get to where I am today, which I freely acknowledge is not at the same level as a pro-electrician. (Note that I said I did frequent references to the code books)
That I say there is a difference does NOT mean that I think one is better than the other, just that there is a difference.
As to the way a GFCI works - I was simplifying a great deal, however the basic theory says that the same number of amps of current flows through EVERY point in a simple circuit, from the source point to where the current returns to the source. If you put an ammeter into the Hot side of a circuit and the Neutral side, they would both be the same, as long as there is only one return path. This is the way it should be in a normal circuit, as the only connection between Neutral and Ground should be at the service panel busbar, and NO current should ever flow in the Ground wire.
In the case where there is a connection between Neutral and Ground at the equipment, SOME of the current will return along the Ground wire and some will return along the Neutral. (Or if there is a connection to some other alternative ground path) The GFCI will detect that it is not seeing the same amount of current in the Neutral as it is in the Hot, and will trip. That is why a GFCI breaker has both the Hot and Neutral wires going to it, with a jumper to the Neutral bus bar, so it can measure these two currents. A GFCI outlet does the same thing, but is less obvious about it since the wiring is internal.
BTW, I just grabbed the instruction sheet for a GFCI I put in when I was installing our pool robot, it says the breaker will trip on a ground current of 5 milliamps or greater. It says in the troubleshooting guide that it will trip if there are more than 6 milliamps of leakage current between the live parts of the wiring (which includes the Neutral wire) and Ground. It also says if there is a connection between Neutral and Ground on the load side, either in the wiring (Which will cause the GFCI to trip as soon as the circuit is energized) or in the equipment.
BTW, I don't like switching Neutrals either, I'm surprised that pellet stoves can get away with it, as I didn't think UL allowed such antics....
Gooserider
