At the end of the summer a huge lightning strike hit a tree behind my house. It's about 20 feet away from my pellet stove, which was turned off but plugged in on a surge protector. My computer and fridge were both fried. My pellet stove (Bosca Spirit) came on by itself at the moment of impact, making a weird buzzing sound. All the error lights were on and it wouldn't shut off. No pellets were dropping--nothing but the humming. I had to unplug it--tried starting it again but it did the same thing. The tech came up a couple months later and replaced the control board. It was August so we didn't run it but he started it-no error lights, it was dropping pellets and he said it was fine.
Fast forward to November when we had to actually use the stove. It seemed to run but them it wouldn't shut down (on thermostat). It also shut itself off prematurely and the blower/fan sounded rough. We called the tech who eventually got back up here and said it just needed a good cleaning. It ran well for a month. A week or so ago it started acting up again, dropping pellets long enough to get a fire going but then it would go into shut down mode and end up with the 3rd error light on. Whether on thermostat or manual it would just keep doing the same thing. We called the tech and since they aren't Bosca dealers (used to be) and they'd have to order the parts, and because they are a couple hours away, they asked us to call US Stove (the US dealer of Bosca) and ask them but so far I haven't been home from work in time to do that so I'm asking here.
Here's the kicker--if we push the manual start button enough times the stove will run perfectly. We just can't let it cool down. If it does, the button has to be pushed numerous times till it decided it's past whatever it is that keeps telling it to shut down. It will run fine then on manual, but if we put it on thermostat it shuts itself off and then cools down enough so when it kicks on it will start fine but shut itself off within 5 minutes and have the error light. We've had to clean the stove while it's still pretty warm in order for us to be able to start it up again on manual, and it'll run perfectly. It's like it has to get past a certain temperature before it'll act like a good little pellet stove.
Any idea what it could be? It's pretty cold here and worse weather is on its way. If we tell the tech what parts he needs he can order them if he doesn't have them--otherwards it will involve him spending hours breaking it down and searching for the problem, and even then he may not have the part.
THANKS
THANKS
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
