Hello everyone! been a lurker for a while, but finally had to actually ask a question that i couldn't find an answer for. I have a Bosca 500 stove. From the knowledge i've gathered this isn't the best stove out there
, but hey it came with the house i bought last year so i'm making the best of it for now.
I'm getting a significant smoke smell after burning 2 tons of pellets so far this year. I shut the stove off earlier today and smoke started billowing out of the top of the glass. I'm talking smoking out the house type. It hadn't shown any signs of the door gasket being bad and upon inspecting it (the dollar bill trick as well as soot build up) there seems to be no fault there. The fault lines with the window gasket.
I took the door off and then removed the window frame/door gasket (4 screwed down hold-downs) and come to find out that the gasket is a U-shaped around the glass. but here's the kicker: IT WAS ONLY ON 3 SIDES!
the top showed no evidence what-so-ever of there ever have been a gasket on it. This clearly was letting air in and coincidentally smoke out. My question is this: why on earth would this be? I've never seen or heard of such a thing. i don't know why you would even have a gasket on the other three sides if you leave a gaping hole on the top side.
any insight would be greatly appreciated. I've also come to find out that the the u-shaped gasket is hard to come by and my best bet is to use the adhesive flat type of gasket and just stick it to both sides. My plan is to seal the glass on all 4 sides, but i'm fearful that this was done by design and that by doing so, i'm inviting in problems.
as a side note, Trae Heat pellets suck...
![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
