Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I'm doing some pre-season re-piping. I need to pipe in the pressure regulator and back-flow preventer for the water fill.
Where is the best spot to tie it in?
Preferably as close to the expansion tank as possible... To minimize risk of water being added to the system by pressure drops from pumps, valves, etc......
The other thing is that a lot of people prefer to keep the autofill turned off unless actually filling the system - in which case it doesn't make a huge difference where you put it, though it is nice if it is where it will help w/ purging the lines. The reasoning behind keeping it off is that if you have a leak, you learn about it sooner as your water level noticeably drops, and it limits the flood size to no more than what is in the system....
I have a hoze bib valve installed at a high point in my system and just connect a water hose when water needs to be added, which is rarely, unless I'm working on the system for some reason. My system is closed, pressurized, and the need to add water in normal operation is zero. The reason the valve is at a high point is that if air is admitted when I hook up the hose, the air quickly moves to an air vent valve and is expelled without running through the whole system.
