Hi I've been reading these forums for a few years, but this is the first time I've posted. I'm "Upgrading" From an old conventional boiler to a new-to-me Jetstream. The Jetstream needs some work and is in the shop now getting overhauled but I need to start figuring out how to install it and was hoping some folks here would be so kind as to lend their experience.
Current setup: Boiler is in the shop, and the water is pumped through 240' of five wrap insulated 1" PEX (Yes, I know that's a long way for 1" PEX, but my house only looses 30,000BTU's hour) to a 60 gallon electric water heater then a variable speed pump injects it into the floor loop.
![Boiler "Upgrade" to Jetstream Boiler "Upgrade" to Jetstream](https://www.hearth.com/talk/data/attachments/155/155255-f7f5c6206306ead23ece56d1901481be.jpg)
The Plan: Boiler stays in shop, Piped in 1.5" Black iron to storage. The electric water heater gets removed, and the variable speed injects straight out of the 1" underground PEX loop from the shop.
![Boiler "Upgrade" to Jetstream Boiler "Upgrade" to Jetstream](https://www.hearth.com/talk/data/attachments/155/155256-a9f78eef4eb0749e0957c5ce4ca68a62.jpg)
The big questions I have are:
How much storage? I can get a 500 gallon propane tank fro around $400, and a 1000 gallon for around $600. But space is at a premium and other than burying the 1000 gallon tank outside I'm not sure where I'd put it. Is 500 Gallons enough? As I understand it the Jetstream is rated for 120,000BTU's hour?
Do I need another pump between the boiler and the storage or will it thermosyphon by itself with 1.5" pipe?
