I'm finally getting around to plumbing and hook-up between the three locations and several components in my wood boiler heating system. Very specifically I'm trying to determine my best option for a boiler tempering valve. After some research I had decided upon the Caleffi "Anti-condensation valve"
280966A
Connection Type: Sweat
Max Temp (F): 140°F
Max Pressure (PSI): 150
Flow Capacity (Cv): 10
Material: Brass
Body Pattern: 3-Way
Application: Point of Source
Standards Met: ASSE 1017
This valve will be connected to a Grundfos UPS15-58 circulator on dedicted loop to my 500 gallon storage tank using 1" copper pipe. In theory the boilers function is to burn hot and heat the water in my tank with no other control interfering. Any demands from the various loads would be drawn from the storage tank. using a delta p circulator. My dilemma and question is whether this is indeed the best choice, and if not what suggestions could be offered. Unfortunately It turns out that this valve is made in Italy, and could be a couple weeks out minimum. Are there other options from a US manufacturer that would meet the same flow rates?
Thanks Rick
280966A
Max Temp (F): 140°F
Material: Brass
Body Pattern: 3-Way
Thanks Rick
