Cheers all,
Due to this wonderful weather I decided to try a burn with valves to storage shut off. Habits are a bit of a problem for me (my wife will attest to this) and I loaded the beast the second time as I always have even though it was already at 200* :shut: . Normally this would not be a problem when heating 3K of water but tonight I am heating only the 1K in the Switzer. When I went down an hour ago to investigate the odd noises coming from the basement I found the beast was pumping steam to my dump zone and the gage was reading 244* @ 8PSI yes only 8PSI My expansion tank is a 500 gal propane tank thank God.
I opened the valve to storage and an hour later the top of the boiler has dropped only 2* with the grundfos4375 running on high.
Storage has raised 30* since I opened the valve. I had raised the setting on the overheat shut down (aquastat) this winter and forgot to turn it down before tonight's burn. With the 2K of storage and the 1K in the switzer I never came close to this temp in the boiler. Wow what a night, I'm glad the welding on the beast has held or my family would be living in the barn (and I'd be in the dog house)!! The interesting thing to me is that I must have a lot of air in the system due to the fact that the air vent hasn't stopped hissing for the past hour. You boiler pro's would be helpful on that thought. It will be a long night tonight with the 14" bed of coals and wood in the fire box. OOPS! This will be a lesson learned the hard way. Happily my wife is enjoying the 75+ temps since I've cranked all 4 zones to max temp.
wood burning is not a hobby and some day I will get it right.........
