Hi all, just joining. First off, is there a search function so I can avoid asking questions already discussed? Maybe it's right in front of me and I'm not seeing it. But I'll go ahead and introduce my concern.
I built a certified food facility in an old (150 yrs) barn, encompassing about 1500 sq ft. It's well insulated (foot thick perimeter walls with an inch of spray foam to the outside, then filled with cellulose. Six inches of spray foam in one section. Anyway you get the idea. We've been heating with electric, the little radiant floor heaters on wheels. With the insulation we've gotten by okay but I want to go to a wood boiler system. I'm thinking gasification boiler with thermal batteries. I'm hoping that will enable me to run the burner full throttle for best efficiency, charge up the batteries and then shut down and draw heat from the batteries until time to fire up the boiler again, hopefully as much as 3-4 days in milder winter weather. I think this will save a ton of wood (and creosote) compared to throttling the fire (and killing the efficiency) when full demand isn't there.
So I welcome comments about this notion in general, but beyond that I'll put a couple of questions out.
Does anyone know of thermal batteries suitable for this application, in the U.S? Seems like Europe is miles ahead of us on this stuff.
If I'm figuring right, I think our peak demand may be less than 50k btuh, so I think the smallest boilers available will be more than adequate, and that's another reason I'm looking at battery storage. I'd had to severely throttle an oversized boiler (which it will be), and probably tar it up it in short order as well as waste a heck of a lot of wood. I'm also leaning to an indoor installation, though willing to consider outdoor.
So comments on what mfg and size of boiler might suit are also welcome. I want one with a track record; a builder who's confident enough of their product to slap a long warranty on it.
I'm glad I finally stumbled on Hearth.com. I've been thrashing all over looking for reliable information. I think I'll find it here.
In case it helps, I was an HVAC tech in my other life, and worked with boilers a fair amount (mostly nat. gas & propane), though I would never claim to be an expert.
I'm 75 now, and in some ways just getting started in life.
andyjim
andyjim
